Ordering MK2S & MM upgrade - come assembled?
If I order the pre-assembled MK2S AND the Multi-Material kit together, will the Multi-Material be assembled with the main printer or will I need to install the MM kit myself?
- 1st "printer" TIKO 3D
- 2nd PRUSA i3 MK2S with MMU v1
- 3rd PRUSA i3 MK2S
- 4th PRUSA i3 MK3 with MMU v2- 5th PRUSA i3 MK4 (upgraded from MK3) with MMU v3 (upgraded from…
Re: Ordering MK2S & MM upgrade - come assembled?
I believe that at the moment you will have to install the MM upgrade yourself.
Peter
Hi Scott,
for now, Multi Material kit is shipped in parts and you have to assemble it yourself. If this is your first Prusa printer, I recommend to use MK2S first, learn basics of 3D printing and then upgrade to the next level, which is Multi Material.
/ Knowledge Base
