MMU Slic3r Prusa Edition default priming gcode for single extruder
Dean
 Dean
(@dean-2)
Can anyone explain what the generic setting in Slic3r (for example 'Generic PLA' settings) is doing with regards to the start of a print and priming? Currently, when I start a print using these setting is extrudes 250mm along the origin and then it traces back seemingly while retracting. This almost always results in no filament extrusion for the first layer of the actual item. I know I could decipher the 'start' gcode area but I'm not very gcode literate.
Respondido : 08/10/2017 6:10 pm
AJS
 AJS
(@ajs)
Re: MMU Slic3r Prusa Edition default priming gcode for single extruder
This behavior has changed in the different versions of the Slic3r.
1) Recommend upgrading to 1_9_0 of the drivers (Slic3r 1.37.1).
2) Go to Printer Settings -> Custom G-code, and copy the "Start G-code" section and past it in here inside a "Code" block. This will help us see what you have going on and see if we can fix it.
I have modified my start code like this:
M115 U3.0.12 ; tell printer latest fw version
; Start G-Code sequence START
T[initial_tool]
G21 ; set units to millimeters
M83 ; use relative distances for extrusion
M104 S170 ; Extruder to 170 (no wait)
M140 S[first_layer_bed_temperature] ; set bed temp
G1 X0 Y0 Z125 ; home X axis Lift to 125 (keep cool)
M190 S[first_layer_bed_temperature] ; wait for bed temp
M109 S170 ; wait for extruder temp to hit 170
M104 S[first_layer_temperature] ; set extruder temp
G80 ; mesh bed leveling while rising in temp
M109 S[first_layer_temperature] ; wait for extruder temp if needed
M203 E100 ; extruder calibration
M92 E140 ; extruder calibration
G1 Z0.250 F7200.000
G1 X50.0 E80.0 F1000.0
G1 X160.0 E20.0 F1000.0
G1 Z0.200 F7200.000
G1 X220.0 E13 F1000.0
G1 X240.0 E0 F1000.0
G1 E-4 F1000.0
G92 E0.0
Respondido : 08/10/2017 6:23 pm
Dean
 Dean
(@dean-2)
Yes, yours looks the same as the default code with some of the temperature stuff ordered differently.
Here's the g-code from the Generic PLA setting
T[initial_tool]
G28 W
G80
G92 E0.0
M203 E100
M92 E140
G1 Z0.250 F7200.000
G1 Z0.200 F7200.000
G1 E-4 F1000.0
G92 E0.0
Respondido : 08/10/2017 6:59 pm
AJS
 AJS
(@ajs)
It is the
G1 E-4 F1000.0
That causes the retraction. You might want to put a skirt around your object to make sure the nozzle is primed.
Respondido : 08/10/2017 7:29 pm
Dean
 Dean
(@dean-2)
Why the retraction in this case? It also causes it to grind pretty badly.
Respondido : 08/10/2017 10:07 pm
Dean
 Dean
(@dean-2)
Also, I did at first add a skirt to compensate but sometimes the quality of the initial skirt perimeters affect the usability of the first layer.
Respondido : 08/10/2017 10:21 pm
Colin
(@colin-4)
Try reducing the E-4 to E-2. It seems to work for me.
Respondido : 09/10/2017 12:45 pm
Dean
 Dean
(@dean-2)
I'm curious why it's retracting at all?
Respondido : 09/10/2017 4:23 pm
Colin
(@colin-4)
Probably to keep it from oozing all the way from the priming line to the skirt.
Respondido : 09/10/2017 7:19 pm
