MMU: different LiveZ for filaments in MM print?
Gobol
(@gobol)
Last day, after successfull upgrade to MM mode (still not convinced, though...) I was trying to print some object using PLA/PVA soluble support. Being after V2MMCalibration for PLA.
The problem arose when PVA comes into play on first layer - it didn't stick to bed, rolls after the nozzle like it wanted some lower LiveZ adjust.
So - is it me doing something wrong, or there should be some option to correct Z position for different materials on first layer ?
Postato : 16/08/2017 10:03 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: MMU: different LiveZ for filaments in MM print?
PVA does not stick to the bed very well; you need glue stick to make it happen.
Peter
Postato : 16/08/2017 10:34 pm
