MMU compatibility with MK2S and MK2.5 upgrades
[Chiuso] MMU compatibility with MK2S and MK2.5 upgrades
All Meshed Up
(@all-meshed-up)
I'm thinking of upgrading my MK2 MMU to an MK2S and then MK2.5. What I can't figure out is if the MMU upgrade is compatible with the other two, specifically the print-head assembly. I know I would gain the benefit of all the body upgrades but what about the print-head?
Postato : 25/02/2018 1:14 am
All Meshed Up
(@all-meshed-up)
Re: MMU compatibility with MK2S and MK2.5 upgrades
It looks to me that if I want to fully upgrade my MK2 MMU that I would need to get the MK2 to MK2S kit, the MK2/S to MK2.5 kit, and the Multi Material upgrade kit from MK2 to MK2.5/MK3.
Right?
Postato : 25/02/2018 5:14 am
I didn't bother with the Mk2s Upgrade, just ordered the Mk2.5 and MMU Mk3 upgrade...
My rods seem to still be OK, from the original Mk1 setup
I modified the extruder strain relief using the mk2 parts and a long bolt to extendthesupport for the cable bundle further from the extruder, additionally I stiffened the strain relief with a short additional length of Nylon to reduce the point loading right behind the extruder. and left it at that.
I had already changed the heat bed cables for more flexible ones, following a breakage,,, this led to me revising the y axis strain relief too...
being a cheapskate i saved my money on the mk2s upgrade
Best of luck with the upgrades.
Postato : 25/02/2018 11:18 am
Steve
(@steve)
Seems about right, at least it's the one I'm following (already did the MK2S upgrade before the MM one) 🙂
XL (5T) / CORE One / MK3S+-MMU3 / MK3S / Mini / SL1S
