MM upgrade single extruder quality
Tomaz
(@tomaz)
Hello,
my only concern that i have upgrading to MM is if print quality stays the same if i use only one extruder or it is lower due to bowden tubes.
Would appreciate the answer from someone who have already get the upgrade and test it.
Best regards.
Veröffentlicht : 09/06/2017 8:49 pm
elmar.n
(@elmar-n)
Re: MM upgrade single extruder quality
Hi Tomaz,
I do not see any big differences, so far.
It seems that the reduced moving mass has been having some positive results.
IMHO does the outside walls looks slightly better than before.
The multicolor "effect" is amazing 😀
I use an MKI with upgrade to 1,75mm and all MK2/MK2+/Mk2MM upgrades.
I found that the new Slicer with MM integration has some, bit at least one bug.
If I use MM setup with only one color it pulls the Filament back after calibration and keeps on pulling when print start.
Well might be a minor gcode thing 🙂
It works with MK2 ZHop setup.
Hope it helps....
Regards Elmar
Veröffentlicht : 09/06/2017 11:01 pm
Tomaz
(@tomaz)
Hello Elmar,
thank you for your HO 🙂 good to hear that
regarding software settings. i'm not affraid they would not solve it in a future :mrgreen:
Best regards.
Veröffentlicht : 10/06/2017 8:29 am
