MM extruder tension spring specs
christopher.d3
(@christopher-d3)
One of the extruder tension springs on my MM upgrade has made a leap to freedom. What am I looking for to replace it? Thanks.
Opublikowany : 17/10/2017 8:51 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: MM extruder tension spring specs
I think you should direst this question to PR support - use the "Live Chat" on the shop pages
Peter
Opublikowany : 17/10/2017 9:54 am
christopher.d3
(@christopher-d3)
Yeah, I finally did that. I now have an order in for two replacements.
Opublikowany : 17/10/2017 8:52 pm
david.w8
(@david-w8)
Could you post here what you replaced them with for posterity?
Opublikowany : 27/10/2017 8:43 pm
