MM and raft
dickie24
(@dickie24)
MM and raft
Hello together,
I do not know, if the Slic3r Multi Material Version supports rafts until now.
When I activate the raft, setting Raft layers to something bigger than 0, the wipetower, is not correct any more.
It stops at the first filament change. Even with the last version.
Dirk
Opublikowany : 11/10/2017 12:29 pm
dickie24
(@dickie24)
Re: MM and raft
Does nobody uses a raft in multicolor mode?
Really?
Dirk
Opublikowany : 13/10/2017 12:24 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: MM and raft
Yes, with certain models.
Works fine for me, but then I don't use Slic3r.
Peter
Opublikowany : 13/10/2017 12:39 pm
dickie24
(@dickie24)
Re: MM and raft
Ok, which slicer is most suitable for that?
Opublikowany : 14/10/2017 3:09 pm
Re: MM and raft
Peter uses Kisslcer. He introduced me to it too.
Regards Joan
Opublikowany : 14/10/2017 5:50 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
Re: MM and raft
The raft certainly used to work with Slic3r and the wipe tower. If you think it is broken, please create a ticket into the Slic3r issue tracker, including your config file and your AMF file. Thank you.
https://github.com/prusa3d/slic3r/issues
Opublikowany : 21/10/2017 6:11 pm
Suraky
(@suraky)
Re: MM and raft
Hello! Any news on this topic?
I'm experiencing the same thing. I have an MMU model using two colours of PLA. If I set it to use a raft, the purge tower is only generated as high as the raft layers.
I'm using Slic3r Prusa Edition 1.37.2, installed today.
I'll try printing without the raft ...
Opublikowany : 29/11/2017 1:36 am
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
Re: MM and raft
Please create a new issue in the github issue tracker and attach your config, AMF file and a G-code. Thank you.
Opublikowany : 29/11/2017 1:53 pm
