Mk2S with MMU won't print at all? Firmware 3.1.0
Nick
 Nick
(@nick-16)
Just upgraded my Original Prusa i3 MK2S with the Multi Material Upgrade, and now it won't print from the SD card at all
I am running
-Firmware v 3.1.0
-Slic3r Prusa Edition v 1.37.2 (on a Mac)
-Drivers (config bundle) v 1.9.2 (included with the 2.0.0 driver download)
-prior to the MM upgrade, the printer worked flawlessly for months
-after upgrading, was able to get through the calibration wizard without issue. Printed the first layer calibration great from the gcode contained within the firmware
-now, I cannot get the printer to produce the "Prusa" model at all (wanted for further first layer calibration.. but I haven't tried other models yet). The printer simply heats up, cycles through the 9 embedded sensors, returns to home, and the SD printed % number on the LCD screen cycles from %1-%100 in about 20 seconds, with no printer action at all. After that, the hot end & bed cool down like it should after a print, but no printing happened.
I have tried
-printing the gcode included with the v 2.0.0 drivers download in the "Mk2MMSingleMode" folder
-generating my own gcode using Slic3r from the Prusa.stl file using "Original Prusa i3 MK2 MM Single Mode" settings
-generating my own gcode using Slic3r from the Prusa.stl file using "Original Prusa i3 MK2 MultiMaterial" settings and only one filament
What gives? Anyone else experiencing this problem?
Veröffentlicht : 24/12/2017 8:40 am
AJS
 AJS
(@ajs)
Re: Mk2S with MMU won't print at all? Firmware 3.1.0
Just guessing, but I am guessing you installed the firmware for the MK2, not the MMU version.
Veröffentlicht : 24/12/2017 8:13 pm
Nick
 Nick
(@nick-16)
Thanks for the response.. I couldn't remember for sure so I double checked and don't think that is my issue. See the below image from my printer. Also, I am presented with the options to load multiple filaments in the menu.
Still not working..
Veröffentlicht : 24/12/2017 10:19 pm
AJS
 AJS
(@ajs)
Yup. Not that. Sorry.
Can't think of anything else but will stew on it.
Veröffentlicht : 25/12/2017 12:08 am
AJS
 AJS
(@ajs)
Try a "factory reset". Sometime the machine keeps things in memory that create problems. A "factory reset" should remove that.
Veröffentlicht : 25/12/2017 12:09 am
Nick
 Nick
(@nick-16)
Thanks aaron.s5.. that did the trick.
I performed a factory reset:
http://help.prusa3d.com/l/en/article/SYvbQ66IXF-factory-reset
re-did the calibration, & first layer adjust.. then everything worked as it should.
Problem solved!
Veröffentlicht : 26/12/2017 7:08 pm
