MK2/S MM Firmware 3.1.0 problem z axe save on printer
michael.i2
(@michael-i2)
Hello,
II just made the firmware update to 3.1.0, I launched the wizzard calibration, everything is ok, everything is //. I run the adjustment of the z axis, I adjust to -550, superb first layer. However, this value does not register in the printer. So I am systematiuement doing the adjustment by hand just before the start of printing, which is not comfortable at all !! Is there a solution? Thank you
Opublikowany : 05/12/2017 6:54 pm
