MK2 MMU how to enable single material mode???
hillinator
(@hillinator-3)
I'm running slic3R on a mac, attempting to print single material parts, I cannot for the life of me find the option to turn on single material mode, I have just been turning off the wipe tower and printing with one extruder, but it doenst prime the tip properly when I Do that, so I would really like to know how to enable single material mode.
I found the switch in prusa control, but I would prefer to have a little more control over settings like temp and such, so having that functionality in slic3r would be great 🙂
Am I just blatantly missing it??? or is there no option to turn it on for slic3r?
Any advice would be greatly appreciated 😀
Publié : 17/12/2017 1:46 am
AJS
 AJS
(@ajs)
Re: MK2 MMU how to enable single material mode???
I just print using the standard settings, but with everything going to the first extruder. I have not noticed a priming issue, but I do have a larger skirt (3 loops) which might mask that completely.
Publié : 17/12/2017 2:36 am
Colin
(@colin-4)
Use the regular old non-MMU version and choose the "Original Prusa i3 MK2 MM Single Mode" profile under "Printer" on the right side of the screen.
Publié : 17/12/2017 3:02 pm
AJS
 AJS
(@ajs)
That version is missing on the Mac version with mk2mm_Slic3r_prusa3d_1_9_2.ini
Publié : 17/12/2017 7:41 pm
hillinator
(@hillinator-3)
Thanks for all the replies! I will see if it shows up in the regular settings but i don’t recall it being there. I just want to use single mode mostly for the more precise layer thicknesses.
Publié : 18/12/2017 10:49 am
hillinator
(@hillinator-3)
found it!! if you load the generic MK2 profiles in slic3r you can select between multimaterial and single material.
Publié : 18/12/2017 9:04 pm
