Message -wait for user - during print
Tom
 Tom
(@tom-17)
I Print my first Multi Material Object - the Marvin. On this Print the printer stops occassionaly with the message "whait for user" 😕 .
In this time the printer stays on the place, temparatur is holding.
Press the knob resume print.
What can i do. I'm not sitting beside the printer all the Time?
Veröffentlicht : 21/12/2017 4:54 pm
Colin
(@colin-4)
Re: Message -wait for user - during print
I just saw this today. 9 hours into a print off the SD card. The print head was paused over the waste tower and "wait for user" (or something similar) was displayed on the LCD. A push on the knob started it back up again.
Anyone?
Veröffentlicht : 23/12/2017 9:19 pm
AJS
 AJS
(@ajs)
I have never seen this behavior, so I am guessing:
1) Make sure the Firmware you installed is the correct one for the MMU. Not the MK2.
2) Make sure the file you are printing is the MMU version.
Veröffentlicht : 24/12/2017 8:18 pm
iloosion
(@iloosion)
There is already other threads opened on this subject, check https://shop.prusa3d.com/forum/original-prusa-i3-mk2-multi-material-f26/-wait-for-user--t6774.html#p55246 for example. Please respond if you have a Raspberry Pi connected to the printer when this happens to you.
Veröffentlicht : 26/12/2017 5:18 pm
