M600 Color Print with MM upgrade
james.c10
(@james-c10)
Does anyone know what the behavior will be if you use an M600 command with the multi-material upgrade?
I have a few prints where I use it to move the extruder assembly out of the way to insert hardware into the print and then continue on. I know I could enter a few lines and move the extruder out of the way and pause for a set amount of time but just entering 1 line in the gcode is so much simpler. If I'm not actually changing the filament color I just reload the filament and continue on.
-Jim
Postato : 22/05/2017 2:22 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: M600 Color Print with MM upgrade
M600 will do the same when using MM upgrade.
However some slicers have a more "elegant" solution in that they allow pauses after a "void".
Peter
Postato : 22/05/2017 3:30 pm
