Loading filament for single color printing
mhackney
(@mhackney)
I know how to select the extruder (1 - 4) using the menus and I know how to load a single extruder. However, this loading assumes MM printing so it does not push the filament all the way to the nozzle. So I have been manually jogging the extruder until filament is extruded and then starting the print. Is this the way to do it or is there a feature or technique to simplify this?
cheers,
Michael
Musings and Experiments on the Art and Science of 3D Printing
Napsal : 22/06/2017 11:07 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Loading filament for single color printing
Michael
KISS is your friend here...
Start GCode will do the tool selection, loading and purging; end GCode will do the unloading.
Start:
; Prefix G-Code
T<EXT+0>
M201 X1500 Y1500 E900 ; set default acceleration
M301 P23.14 I1.78 D75.12 ; set PD for extruder heater - specific for my printer
M304 P56.09 I2.39 D328.54 ; set PID for bed heater - specific for my printer
G21 ; set units to millimeters
M83 ; use relative distances for extrusion
M140 S<BED> ; Heat the bed
M104 S170
M190 S<BED> ; Heat the bed and wait
M109 S170
G28 W
M104 S<TEMP>
G80 a-100 b50 c150 d90 e135 f40 g0 h-70 ; specific for my printer
M109 S<TEMP>
G92 E0.0
G1 Y-3 Z0.250 F7200.000
G1 X50.0 E75.0 F1000.0
G1 X160.0 E10.0 F1000.0
G1 X220.0 E6 F1000.0
G1 X240.0 E2 F1000.0
G1 Y-1.
G1 X40 E15 F1000
G1 X0 E2 F1000.0
G1 E-4 F4800
G92 E0.0
End:
; Postfix GCode
G1 Z<Z+1.0> E-4 F7200 ; Lift and retract
G1 X0 Y200 F3600 ; move bed for easy removal
G1 E12 F2100 ; unload filament
G1 E-80 F5000
G1 E-5 F3500
G1 E-5 F2400
G1 E-2 F1000
G1 E10 F300
G1 E-10 F300
G1 E10 F600
G1 E-10 F600
G1 E10 F900
G1 E-10 F900
G1 E15 F1200
G1 E-15 F1200
G1 E5 F600
G4 S1 ; pause 1 second
M107 ; turn off fan
M104 S0 ; turn off temperature
M140 S0 ; turn off heatbed
M84 ; disable motors
I think you can do similar in Slic3r, but I never got that far...
Peter
Napsal : 22/06/2017 11:12 pm
Dan
 Dan
(@dan-2)
cheers,
Michael
Dear Michael,
have you been able to solve your manually jogging issue?
Napsal : 28/08/2017 11:21 am
PJR
 PJR
(@pjr)
Just select the correct profile in your slicer.
Peter
Napsal : 28/08/2017 12:39 pm
Dan
 Dan
(@dan-2)
Peter
That won't do the job. The loading procedure Feeds the Filament into the the steel tubes in the multiplexer only. Thus in General I Need an extra 100 mm+ to start Extrusion. Your start script does its job (Thanks for that, not tried the step by step end script yet), as soon as I made manually sure that I have constant extrusion capabilities.
best
Dan
Napsal : 28/08/2017 2:30 pm
PJR
 PJR
(@pjr)
Dan
Slic3r should do exactly the same if you select the correct profile.
Peter
Napsal : 28/08/2017 3:16 pm
