Knight of Egypt multi color print?
devilhunter
(@devilhunter)
Since a good while ago, Prusa is showing off a couple of multi color prints for the multi material kit.
Now that i have one to experiment with, i'd like to print the Anubis/Knight of Egypt chess piece from here:
http://www.prusaprinters.org/update-multi-material-upgrade-2/
Only thing is, i can't find the multi material/quad color print anywhere.
The quad material version custom made by Prusa research and not released for the public?
Opublikowany : 12/06/2017 8:46 pm
Jindřich Beneš
(@jindrich-benes)
Re: Knight of Egypt multi color print?
Anubis can now be downloaded here:
https://www.thingiverse.com/thing:2384172
Opublikowany : 14/06/2017 11:49 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Any chance of you uploading the SLTs for your models please?
Peter
Opublikowany : 19/06/2017 3:18 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
Peter,
you may import the amf into Slic3r and then export all the parts together as a single STL. I believe your kisslicer can handle a multi-part STL.
Vojtech
Opublikowany : 22/06/2017 3:03 pm
PJR
 PJR
(@pjr)
Peter,
Vojtech
Yeah, I tried that, but when exporting as a single STL from Slic3r, many of the parts were combined and there were many errors in the file.
Peter
Opublikowany : 22/06/2017 3:15 pm
