glass bed with mm
outpost.a
(@outpost-a)
glass bed with mm
Hi I am going to try a glass bed following this link here http://www.prusamk2.com/printing-on-glass-with-youre-prusa-i3-mk2-ohhh-so-smooth/
and his gcode in SLI3R. Does anyone see any potential issues, as his code seems to work on a single extruder but will multiple extruders cause an issue? It's basically replacing the startup script with the one below.
M300 S1567 P240
M301 P22.18 I1.27 D96.74 ; PID Tuning for your printer, you can delete this line if not used
G80 ; mesh bed leveling
G1 Y-3.0 F1000.0 ; go outside printing area
G1 F600 Z+100 ; Raise the print nozzle out of the way
G4 P30000 ; pause for 1 minute
M300 S1567 P240 ; Play a Beep
M117 One minute remaining ; One minute remaining warning
G4 P30000 ; pause 1 more minute
G1 Z2.3 ; consider glass thickness Measure your glass thickness first
G92 Z0 ; Set absolute positioning for remaining print
Veröffentlicht : 24/12/2017 3:42 am
