Filament Profiles
Hi All
i just finished the upgrade to MM and wanted to do my first test print, the gcode that comes with the software is for PLA and the slic3r software has only ABS and PLA in the filament profiles, while all my filament is PETG(dump mistake), my question is can i use the filament profiles from the normal slic3r on the MM. i know PR is still testing other filament types but i only have PETG, so any advise is appreciated.
Keep on smiling -
Opublikowany : 03/07/2017 10:17 pm
Re: Filament Profiles
Yes you can use PETG. Just adjust the temperature either in the gcode file at the beginning or using tune right after you start the print from the SD card.
Opublikowany : 04/07/2017 1:35 am
