Feed rate control
I seem to remember seeing this somewhere before, but I don't remember seeing if there is a solution:
I'm printing a 3 color model that has a number of finer details (spheres) on the first layers. To improve adhesion and quality I've decreased the feed rate, but have found that after every filament change the feed rate goes back to 100%. Is there a way to change this behavior?
Publié : 10/11/2017 2:03 am
Topic starter
answered:
Re: Feed rate control
I suppose the M220 S100 s are all there because all loads/unloads require a certain feed rate to work correctly? The only solution I've come up with so far is to modify the gcode (replacing the ; CP TOOLCHANGE END comment with the desired M220 command).
Publié : 10/11/2017 8:59 pm
