Failing or Missing Layers; Stepper Problem or Slic3r?
CvK
 CvK
(@cvk)
https://photos.app.goo.gl/5BlqdX8FSgUjqC2b2
https://photos.app.goo.gl/818nSOhEQd9HHn7R2
Hi All,
I'm having some weird issues with 3d benchy and a new MM install. Can someone help me figure out whats going on. At some point in the print the extruder or stepper fails to lay down one color. In the video above, you'll see at around 00:55-01:05 black fails to lay down. Also, please see attached photos. So far the Marvin 2 color print has worked and single color prints.
Respondido : 19/09/2017 12:37 am
AJS
 AJS
(@ajs)
Re: Failing or Missing Layers; Stepper Problem or Slic3r?
Were these pre-sliced Benchy's or ones you sliced?
Respondido : 19/09/2017 1:40 am
daniel.t5
(@daniel-t5)
I think I've seen this problem myself, and have yet to diagnose it. I'll post my pics when I get home tonight, I'd love some feedback on this.
Respondido : 19/09/2017 2:55 am
CvK
 CvK
(@cvk)
I used slic3r to prep them, then sent the gcode to octoprint and printed from there.
Here's a print isolating each stepper showing steppers 1-4 from left to right. I got the same layer failure on steppers 1-3 but 4 (green) seems fine. Maybe it's Octoprint?
I can post the timelapse sometime Tuesday if that helps.
Respondido : 19/09/2017 6:02 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Most likely cause: blockage due to stringing.
See this thread: http://shop.prusa3d.com/forum/original-prusa-i3-mk2-multimaterial-f26/blockage-troubleshooting--t4643.html
Peter
Respondido : 19/09/2017 9:44 am
CvK
 CvK
(@cvk)
Peter
Hi Peter,
Thanks, but I'm not clear on what stringing is. Could you point me in the right direction? Also do you know why only does it for a few layers then recover?
Respondido : 19/09/2017 1:44 pm
PJR
 PJR
(@pjr)
Stringing of the filament tip during unload. It can block another filament from loading properly and then when that filament is unloaded, it unloads too far, so misses the next layer or two.
It can also remove the string left behind by the bad unload.
Drop your temps by 5 degrees or so. Print slower if necessary.
Peter
Respondido : 19/09/2017 1:58 pm
AJS
 AJS
(@ajs)
Octoprint could not have an effect like this.
I agree. Blockage.
Respondido : 19/09/2017 3:38 pm
CvK
 CvK
(@cvk)
Hi guys,
After taking your advice, I dropped temps to 190 and slowed the print down. I've dropped temps twice and the filament continues to jam in the hotend and is unable to retract very similar to http://shop.prusa3d.com/forum/original-prusa-i3-mk2-multimaterial-f26/jamming-in-the-steel-tubes-t4914.html
I'm seeing repeated print failures halfway or even 80% through the print, even though the first half is perfectly fine. Sometimes its one extruder, then another. It's even worse now with total jamming occurring on the bearings. My recent attempt at the 3dBenchy was better but far from perfect. I have one of the bowdens that is only tapered internally on one end, if that helps.
Respondido : 22/09/2017 6:17 am
PJR
 PJR
(@pjr)
Have you read through this thread: http://shop.prusa3d.com/forum/original-prusa-i3-mk2-multimaterial-f26/blockage-troubleshooting--t4643.html
Peter
Respondido : 22/09/2017 10:47 am
CvK
 CvK
(@cvk)
Peter
Thanks Peter,
I think it ended up being too much tension from the filament roll not unrolling properly and snagging because of the back feed causing the roll to loosen then the line to cross weirdly on the roll, so when the material switched back, the roll wouldn't feed as well and cause a jam. I didn't notice initially because the roll would recover after the stepper pulled the knot out. The one single material failure looks like it was also because of a filament roll feed failure.
Respondido : 23/09/2017 8:57 pm
