Extruder running backwards on print?
1ProjectAWeek
(@1projectaweek)
I'm currently working on printing from a single extruder. The V2MMCalibration_ABS.gcode seems to print just fine, load and unload filament routines are working fine, however slicing my first model using Slic3r v1.35.5-prusa3d and the new presets results in no extrusion as the filament is running backwards. I checked the cable from the super switch to RAMBO and it looks right according to this picture:
Reference:
Mine:
I have octoprint hooked up as well. Manual extrude commands work... So I think it's the slicer...
And yes, now looking at the G-code, this doesn't seem right:
; generated by Slic3r 1.35.5-prusa3d on 2017-07-04 at 10:00:04
; external perimeters extrusion width = 0.45mm
; perimeters extrusion width = 0.45mm
; infill extrusion width = 0.45mm
; solid infill extrusion width = 0.45mm
; top infill extrusion width = 0.45mm
; first layer extrusion width = 0.42mm
M190 S100 ; set bed temperature and wait for it to be reached
M115 U3.0.12-RC1 ; tell printer latest fw version
; Start G-Code sequence START
T99
M109 S255
G21 ; set units to millimeters
M83 ; use relative distances for extrusion
G28 W
G80
G92 E0.0
M203 E100
M92 E140
G1 Z0.250 F7200.000
G1 X50.0 E80.0 F1000.0
G1 X160.0 E20.0 F1000.0
G1 Z0.200 F7200.000
G1 X220.0 E13 F1000.0
G1 X240.0 E0 F1000.0
G1 E-4 F1000.0
G92 E0.0
; Filament gcode
T99 is to "deselect tool" I never see it run another "T" code.
I definitely have the right extruder selected in Slic3r:
I'm trying not to overthink anything here, but I don't think I should have to manually enter the extruder G-code with the provided Slic3r and profiles, right? What am I missing here?
Bill Church
Saint Petersburg, Fl USA
Original Prusa i3 Mk3 Kit Stock v3.8.1-2869
Original Prusa i3 Mk2 Kit Stock v3.2.3
Napsal : 04/07/2017 4:05 pm
1ProjectAWeek
(@1projectaweek)
Re: Extruder running backwards on print?
Maybe Solved? Ok, so I didn't realize that even if you're printing from a single extruder, you need to run the Gcode through the Multi Material post processor. I did that and I see the G-code actually now has a T0 in place of a T99...
I'm waiting for it to heat up and print, but that's probably got it.
If I'm just printing from a single extruder, is it ok to change the start G-code from T99 to T0? Thinking I just create a separate printer profile for this...
Weird that it runs backwards, or at all with T99...
Bill Church
Napsal : 04/07/2017 4:14 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
See this post: http://shop.prusa3d.com/forum/original-prusa-i3-mk2-multimaterial-f26/extrusion-coming-late-t4904-s10.html#p35971
Peter
Napsal : 04/07/2017 5:31 pm
1ProjectAWeek
(@1projectaweek)
Thanks Peter, that makes sense... What doesn't make sense is this is the most recent version of the profile from PRUSA, so it shouldn't be "outdated".
Re: Extrusion Coming Late
Tue Jun 27, 2017 3:37 pm
Your slic3r star g-code shall contain the following line:
T[initial_tool]
The [initial_tool] will be replaced by the starting extruder id.
I believe you either use an outdated or incorrect Slic3r profile.
I'm just trying to be a normal consumer and not overthink things, I guess that's what I get... lol
I did a diff of the G-Code before and after and the major differences I saw were related to the start and stop g-code which is easy enough to modify... Just wanted to make sure I wasn't going crazy... Going to copy that printer profile and make a new one for single extruder prints I guess.
Bill Church
Napsal : 04/07/2017 10:20 pm
PJR
 PJR
(@pjr)
Of course, us KISS users don't suffer these issues ... 😉
Peter
Napsal : 04/07/2017 11:21 pm
