Drivers 1.9.0 with Slic3r Prusa Edition
Jakub Dolezal
(@jakub-dolezal)
Member Admin
UPDATE: This package is no longer the latest, more here: https://shop.prusa3d.com/forum/original-prusa-i3-mk2-multi-material-f26/drivers-1-9-2-with-slic3r-pe-and-prusacontrol-t6839.html
Hi there,
this is the newest release of drivers and software for your printer. Included is the latest stable release of Slic3r Prusa Edition. For newcomers to 3D printing is prepared another slicer PrusaControl, but keep in mind it is still in beta.
What is new?
Slic3r PE - updated to 1.37.1
PrusaControl - updated to 0.9.3_390_beta (with support for Multi Material)
Multi Material - new 3 material test object added – Big Whale Jumping by GabirelYun (uses PLA and BVOH)
Multi Material - new print settings for 0.6mm nozzle
Multi Material - printer tests all used extruders prior to the print on the first layer at the front of the print bed to verify proper filament insertion.
Supported printers:
This driver's package includes latest profiles for MK1, MK2/S as well as their Multi Material upgraded versions.
Download link: http://www.prusa3d.com/drivers
Slic3r PE full changelog: https://github.com/prusa3d/Slic3r/releases/tag/version_1.37.1
PrusaControl homepage: https://prusacontrol.org
How to install drivers on MacOS: http://manual.prusa3d.com/Guide/Installing+Slic3r+Prusa+Edition+-+macOS/404
Assembly manuals
/ Knowledge Base
Napsal : 22/09/2017 12:13 pm
Jakub Dolezal
(@jakub-dolezal)
Member Admin
Re: Drivers 1.9.0 with Slic3r Prusa Edition
testing post
Assembly manuals
/ Knowledge Base
Napsal : 04/10/2017 9:21 pm
