Drivers 1.8.0 with Slic3r Prusa Edition
Jakub Dolezal
(@jakub-dolezal)
Member Admin
UPDATE: There is a newer version, please check this thread http://shop.prusa3d.com/forum/original-prusa-i3-mk2-multimaterial-f26/drivers-1-9-0-with-slic3r-prusa-edition-t5968.html
Hi there,
this is the newest release of drivers and software for your printer. Included is the latest stable release of Slic3r Prusa Edition. For newcomers to 3D printing is prepared another slicer PrusaControl, but keep in mind it is still in beta.
What is new?
General - Slic3r PE is updated to 1.36.2
General - Slic3r PE is now signed for macOS (Apple)
Multi Material - added print settings for more effective use of water soluble support (NORMAL SOLUBLE INTERFACE)
Multi Material - improved sample G-code - Gear Bearing
Multi Material - added sample G-codes for Multi Material Single Mode
Multi Material - smart wipe tower is better attached to the print surface (heatbed)
Multi Material - improved cooling of printed object
Multi Material - multiple STLs can be Drag&Dropped simultaneously (Slic3r asks if they should be merged as multi material object)
Supported printers:
This driver's package includes latest profiles for MK1, MK2/S as well as their Multi Material upgraded versions.
Download link: http://www.prusa3d.com/drivers
Slic3r PE full changelog: https://github.com/prusa3d/Slic3r/releases/tag/version_1.36.2
PrusaControl homepage: https://prusacontrol.org
How to install drivers on MacOS: https://prusa3d.dozuki.com/Guide/Installing+Slic3r+Prusa+Edition+-+macOS/404
Assembly manuals
/ Knowledge Base
Opublikowany : 14/09/2017 12:00 pm
