ColorPrint Issue with MM
eric.h12
(@eric-h12)
So my MMU is working fine for single color, single piece prints and also with multicolor prints that contain multiple pieces. My issue is when I try to print a single piece with color changes at certain layers, which should be simple with ColorPrint.
However, when I slice an object in Slic3r, import it into ColorPrint and set color changes, and then run that through the Post Processor, it does not work. Trying to print the resulting file does not print a wipe tower and does not switch extruders at the set layer heights.
Is there something I am missing?
Posted : 31/10/2017 6:10 pm
