Colorprint by layer with multiple extruders
jonn
 jonn
(@jonn)
I want to create a gcode that changes color on layer height. But instead of changing the color in one extruder I want the machine to use a different extruder.
Basically I want to do an automated M600 command where I don't have to change the filament.
Basic flow:
1 Load all the different color in different extruders
2 Print stuff
3 Finish layer
4a Save position of nozzle
4b Move nozzle to corner
5 Retract filament in current extruder enough to not obstruct
6 Change active extruder
7 Extrude enough to clear the color
8 Return to stored position
9 Continue print
10 Jump to 3 to repeat if needed
Does anyone know the exact commands 'inside' the M600 command?
I don't know how to do step 4a and 8. Also, what length do I need for step 5 & 7?
Any help is greatly appreciated 🙂
Thingiverse profile.
Napsal : 06/08/2017 6:58 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Colorprint by layer with multiple extruders
Well, the easiest way to do this is to split the model into 2 meshes (I would use either Tinkercad or NetFabb Basic).
Slice so the lower mesh prints with one extruder and the upper with a different one.
Peter
Napsal : 06/08/2017 8:04 pm
jonn
 jonn
(@jonn)
I thought about that, the problem then becomes that you need the wipe tower and then I can't do variable layer height :/
Napsal : 06/08/2017 8:29 pm
PJR
 PJR
(@pjr)
You need the wipe tower.
http://shop.prusa3d.com/forum/original-prusa-i3-mk2-multimaterial-f26/variable-layer-height-mm-printing-t5361.html
Peter
Napsal : 06/08/2017 8:35 pm
jonn
 jonn
(@jonn)
I read that one, it's pretty nice, but sadly that doesn't help me :/
I tried to read the firmware to figure out how M600 works, but I got nowhere
Napsal : 06/08/2017 9:15 pm
PJR
 PJR
(@pjr)
Well, it's all there:
// Filament change configuration
#define FILAMENTCHANGEENABLE
#ifdef FILAMENTCHANGEENABLE
#define FILAMENTCHANGE_XPOS 211
#define FILAMENTCHANGE_YPOS 0
#define FILAMENTCHANGE_ZADD 2
#define FILAMENTCHANGE_FIRSTRETRACT -2
#define FILAMENTCHANGE_FINALRETRACT -80
#define FILAMENTCHANGE_FIRSTFEED 70
#define FILAMENTCHANGE_FINALFEED 50
#define FILAMENTCHANGE_RECFEED 5
#define FILAMENTCHANGE_XYFEED 50
#define FILAMENTCHANGE_EFEED 20
#define FILAMENTCHANGE_RFEED 400
#define FILAMENTCHANGE_EXFEED 2
#define FILAMENTCHANGE_ZFEED 15
#endif
But quite honestly, I really do think you are going down the wrong path and what I posted earlier is the right path to go down.
Basically after loading the filament, you need to purge between 30 and 100 mm of filament - depending on type and colour. Problem is that it's not just a simple purge.
Peter
Peter
Napsal : 07/08/2017 10:31 am
jonn
 jonn
(@jonn)
I kind of made a workaround. But not quite like I planned.
I used the wipe tower and just stitched two gcodes together where the only difference is layer height.
Slice 1 print to 1.4mm with 0.2+0.3 layer height and from there I used slice 2 with 0.15 layer height.
Quite a tedious process and I hope Slic3r PE soon gets MM variable layer heights.
Thanks for your help 🙂
Napsal : 10/08/2017 7:46 pm
