Changing temp for gear bearing
DaveinMI
(@daveinmi)
I've been printing a couple of the presliced gear bearings from the Prusa sample folder. But I'd like to change the nozzle temperature on two of the extruders to 205, instead of the default 210. So while printing I go to "tune" and change the temp. but the next time that extruder is used, it goes back to 210. Just wondering why, or if anyone else has seen this happen. Thanks !
Veröffentlicht : 14/11/2017 1:38 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Changing temp for gear bearing
Because there is a temperature command for each tool change.
You need to re-slice the model yourself or (more difficult) edit the G-code and change every incorrect instance of the temperature.
Peter
Veröffentlicht : 14/11/2017 2:02 pm
DaveinMI
(@daveinmi)
Thanks ! I think I'll do that, as I want to do two at a time..
Veröffentlicht : 15/11/2017 1:59 am
