Can the MultiMaterial upgrade be combined with a diamond hotend?
WonderLabWoman
(@wonderlabwoman)
Hi all,
I am still relatively new at this, so forgive me if it's a silly suggestion, but I was wondering: would it be possible to combine the multi-material upgrade with a diamond hotend? They seem to be made for each other 😉 !
That way, you choose to blend colours instead of switching colours (and even prevent using a waste-tower), right? Or am I overlooking something?
Thank you very much for your reactions.
Opublikowany : 25/09/2017 11:13 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Can the MultiMaterial upgrade be combined with a diamond hotend?
No. You can only drive 1 extruder motor at a time.
Peter
Opublikowany : 25/09/2017 11:36 am
WonderLabWoman
(@wonderlabwoman)
Thank you PJR for you answer!
That's a pity! Would you mind explaining why? Is it a hardware restriction or a software restriction?
Kind regards 🙂
Opublikowany : 25/09/2017 12:12 pm
PJR
 PJR
(@pjr)
RAMBo only has a single E-Stepper driver
Peter
Opublikowany : 25/09/2017 12:37 pm
WonderLabWoman
(@wonderlabwoman)
Thank you Peter, for elaborating!
Even the new MK3 EINSI RAMBo?
That would call for another (custom) upgrade... 😯
Kind regards! 😉
Opublikowany : 25/09/2017 12:58 pm
PJR
 PJR
(@pjr)
The Mk3 Einsy RAMBo is no different in this respect (and many others) to the 1.3 RAMBo. Still a very cut-down controller with a total of 4 stepper drivers and hugely underpowered MCU.
Peter
Opublikowany : 25/09/2017 1:44 pm
richard.l
(@richard-l)
Member Moderator
I'd like to know their thinking behind using this board instead of something like the Duet WiFi. There must be a reason.
Opublikowany : 25/09/2017 5:06 pm
PJR
 PJR
(@pjr)
Yeah, I would like to know the official line as well. Even the Arduino Due would have been just so much better, the porting of the firmware would not have been too difficult (a lot of it is already available).
I am guessing, here, but the Trinamic drivers can interpolate steps (but they only do this "accurately" above 16 Hz I believe). They are controlled via SPI so I would hope that the stepping will be controlled in real time (ie move to 256 steps when slow enough for the MCU and interpolated 1/16 or 1/8 stepping for the longer, fast movements).
Still, this controller card is an advertiser's dream; there are so many "good" bits to sell... Most of these "good" bits merely address faults in the Mk2 or address issues most of us don't have (power loss, Octoprint - on a Pi Zero??? etc).
Peter
Opublikowany : 25/09/2017 5:45 pm
richard.l
(@richard-l)
Member Moderator
Peter
I would like to find more information on this board but the github has a technical drawing and not much else.
Octoprint on a Pi Zero is just asking for trouble. The WiFi is weak and the processing power of the Zero will barely be enough. I have a Pi2 that struggles at times with a better external wifi and a camera for monitoring.
I'm like you, most of what this addresses isn't a problem for me. I'll eventually buy an MK3 and donate my non-MM to the local library.
Opublikowany : 25/09/2017 6:59 pm
AverageWhiteGuy
(@averagewhiteguy)
Thomas from youtube said it best.. he keeps hinting at beagle bone.. then I saw this:
It looks like the Replicate is a much better board. Like he says in the video, your going from a basic firmware to a operating system. In this case, linux. (Not very user-friendly.) And you have to work on all the tinkering to make it "go".
I don't know if I want to spend that much though.. between the Beaglebone, and the Replicate shield... $155, then more once you start adding other accessories, like the Manga Screen 2 ($99). Note: The pricing he mentions in the video has changed.
You can find replicape's page:
https://www.thing-printer.com/product/replicape/
I did contact prusa support, because I have a hunch the new utilmachine board uses a 32 bit processor.
War... War never changes.
Opublikowany : 25/09/2017 8:49 pm
PJR
 PJR
(@pjr)
Which means that it's difficult at best to get to the interrupts; something you can do easily with the Arduino IDE and is almost essential (totally essential with a 16MHz MCU) on a 3D printer.
The Einsy is an old design, based around the ATMega 2560; same as the RAMBo 1.3 card. This really is a sideways movement. The Pi Zero is a definite downgrade.
Peter
Opublikowany : 25/09/2017 10:38 pm
