Bowden tube length configurable?
roy.e
(@roy-e)
Can the Bowden tube length be configured? I know the exact distance is important for filament loading.
I'm thinking about making a design to mount my extruders and filament spools on my pegboard behind my printer. I can probably still do it without changing the length but it would be easier to have that freedom.
Postato : 02/06/2017 4:24 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Bowden tube length configurable?
Yes
I believe it is option 4 in the factory reset menu.
Eace tube length can be set.
Peter
Postato : 02/06/2017 8:58 am
BryanArnold
(@bryanarnold)
Digging up an old thread. Researching building a Zaribo 320, and I would need to adjust the length of the bowden tube.
How do I get to that menu? Would I need to factory reset and get to it there?
Postato : 16/11/2017 2:42 am
PJR
 PJR
(@pjr)
You reset the printer with the menu button held down. When it restarts a "factory reset" menu is presented; one of the options is to change the tube length.
Peter
Postato : 16/11/2017 9:45 am
BryanArnold
(@bryanarnold)
Thanks!
Postato : 27/11/2017 5:38 am
