Anyone want to try my color file?
AJS
 AJS
(@ajs)
Hello all,
I am awaiting my MM upgrade (ordered in January), and am working on some files while I wait.
It is my understanding that to do the multi-material you start with a .stl file for each color.
So, I have been working on a design that can put out 4 separate .stl files. It will be a while before I can print it, so I was wondering if there is anyone with a MMU that is itching for new 2 or 4 color files to test/print and would like to test this design.
It is customizable (can put in two different sets of initials) and I can do a 2 or 4 color version. It is a fidget spinner that is an evolution of emmett's planetary gear (with herringbone gears) with a large number of changes to make it a fun fidget toy, and printer show off item. I have printed a number of them single color, and people seem to really like them.
Anyway, if anyone would want to play with this, please let me know, I would love to see one printed.
Thanks
Aaron
Opublikowany : 25/05/2017 4:52 am
Clive
(@clive)
Re: Anyone want to try my color file?
I'll give it a go, my MM upgrade should arrive within the next week or two.
Opublikowany : 25/05/2017 5:23 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Yes... and no. With some slicers you are able to assign meshes to extruders and others you assign files to extruders.
Peter
Opublikowany : 25/05/2017 10:17 am
CptKirc
(@cptkirc)
Hi Aaron,
just upload it to thingiverse or send it to me directly - i´ll give it a try on my quad MM 😉 There are not many designs out there in MM so that would be another one to gain experience.
Best regards
Christian
Opublikowany : 26/05/2017 12:30 am
PJR
 PJR
(@pjr)
There are a lot more than you think, especially if you assign meshes to extruders (see my earlier post).
Peter
Opublikowany : 26/05/2017 9:31 am
