Anatomy of the multi-material filament pathway
TimW
 TimW
(@timw)
I wondered if anyone could point me at a description of the anatomy of the multi-material filament pathway? Specifically interested in the various choices made in its construction. For example, why are their little metal tubes in the splitter rather than it just being printed, or contains ptfe tubes? Are the angles of the tubes chosen specially? Could you have a central tube rather than them all being angled? Was the reduced length of the ptfe tube from the hotend (compared to the non-MM hotend) important? Is it important that the extruders have the bondtech drivegears? There are lots of engineering choices here and I'd be very interested in reading more about them.
Thanks
Respondido : 10/09/2017 7:33 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Anatomy of the multi-material filament pathway
Blimey. You don't want much... How long have you got???
Stainless Steel "Cooling Tubes". They do exactly as described.
Bondtech gears to add torque to the filament drive - and they are much more precise than the previous brass drives (where different E-Steps were required for each ,extruder)
Special 1.9mm ID PTFE to form the end of the filament for the next load.
Adjustment to the heat break to help cater for stringing on unload.
Requirement to get filament tip into cooling tubes as quickly as possible.
You should have been part of the beta testing!
Peter
Respondido : 10/09/2017 5:24 pm
TimW
 TimW
(@timw)
Thanks Peter. I don't suppose you know if Prusa will ever write this up and/or present it at come conference? It'd be a really interesting read to see how they walked though the various engineering compromises to get to the final product.
Respondido : 10/09/2017 8:35 pm
PJR
 PJR
(@pjr)
No, sorry; I have no idea what PR will or will not document.
I only know what we were told during beta tests. And of course, things are still being changed/improved.
Peter
Respondido : 10/09/2017 8:51 pm
Robert
(@robert-26)
I think it's interesting to watch the extruder move the filament back and forth in the cooling tube to form it into a nice round shape with a rounded tip as it cools. I'll bet coming up with that was a good light-bulb moment.
Respondido : 10/09/2017 9:20 pm
PJR
 PJR
(@pjr)
Yes, it was in interesting moment, but strangely, using PTFE cooling tubes, no movements are necessary.
Peter
Respondido : 10/09/2017 11:06 pm
TimW
 TimW
(@timw)
Way too much time on my hands 🙂
Bearing in mind I know almost nothing on this subject, I though the idea was that the filament was cold once it left the cooling part of the hotend, so why the specific steel cooling tubes? And given that they're are obviously necessary, why metal tubes at all - ptfe wouldn't work as well?
I do rather like the bondtech drivegears, but given the cost compared to the alternative (I'm sure Prusa didn't pay the $50 they charge on their website, but still more expensive than the old system) I assume its just necessary to push filament though such a long bowden tube?
Is this a tolerance thing. If they use 2mm here, the chances are that it'll stick in other 2mm places?
Okay.
So why is that? Couldn't you let the filament cool in the cold bit of the hotend before yanking it back into the splitter?
I know far too little to have been helpful.
Thanks
Respondido : 11/09/2017 7:39 pm
PJR
 PJR
(@pjr)
Tim
I will cover things in a little bit more detail...
The ID of the PTFE is 1.9mm and that of the cooling tubes is 1.95mm. Initially the former was 2.0 and the latter 1.85, so the tip forming was carried out inside the cooling tubes. The problem there was filament diameter.
Note that the PTFE is initially nominally smaller ID than the cooling tubes
So things were switch around and the PTFE became the primary tip forming place, and the tubes just for cooling.
This method ensure that the filament will feed into the hot end on the next load (maybe 99.99% of the time...).
PLA has a "glass transition temperature" of around 62 degrees; it's pulled out of the hot end at maybe 215 degrees and is malleable for quite some time. This cooling process must be carried out in a "controlled" manner in order maintain a nice clean end.
Regarding the use of PTFE, see my earlier comment. But, there is a problem with PTFE in that it is abraded by filament - even quite soft stull - and it will wear.
The additional torque provided by the Bondtech gears is more to overcome the stiction of the filament inside the cooling tubes and any stringing that may have occurred during unload. There were quite a few models printed with the brass drive gears (I had even written a post-processor to handle the differing E-Steps) before the Bondtech ones were introduced.
Hope this covers your queries.
Peter
Respondido : 11/09/2017 8:54 pm
Kryssie
(@kryssie)
Where can I find spare cooling tubes? They don't seem to be listed anywhere...
Fair farren
Respondido : 23/09/2017 12:06 am
PJR
 PJR
(@pjr)
http://shop.prusa3d.com/en/multi-material-spare-parts/167-mmu-multiplexer-stainless-steel-tube.html
You will need to speak with "Live Chat" ask them for access and then ask them to put some in stock for you.
Peter
Respondido : 23/09/2017 7:11 am
