Always load extruder 1
fra1887
(@fra1887)
Hi everyone, I had a Prusa mk2s and I installed the multilaterally upgraded.
I've updated the firmware but I can not load different filaments.
When the loader's printer 1 is ok, when I ask to load filaments 2 - 3 - 4, move the extruder 1 and I can not load them, it seems that the printer does not recognize the 4 extruders but only 1 (the first), can you help me?
Thanks so much
Respondido : 22/10/2017 1:44 pm
fra1887
(@fra1887)
Re: Always load extruder 1
To be clearer, any filament recall (1 to 4) moves only extruder 1
I hope the video clarifies this, thanks
Respondido : 22/10/2017 6:49 pm
AJS
 AJS
(@ajs)
The ribbon cable that connect the RAMBO to the multiplexer board is not installed correctly. Slide over one pin. This happened to me too.
Respondido : 22/10/2017 8:59 pm
fra1887
(@fra1887)
Correct answer, thank you very much
Respondido : 24/10/2017 7:48 pm
