After a successful print
I find that, while the MMU adds a lot of hassle to prints, I _CAN_ get it to print. What I CAN'T get it to do is _unload_ the last used filament correctly in either the latest slic3r OR PrusaControl.
When I go to print the next thing, and if it uses a different extruder, and if I forget to preheat and remove the last used filament, I'll get a jam every single time.
Am I missing something obvious? Should there be some G-code at the end that parks the filament and leaves it in a usable state?
Re: After a successful print
It appears my prints are doing a park routine at the end. Are you on the latest firmware/slic3r?
Preheating is key. I usually reset the printer after a print is done and then preheat/unload.
That being said the multiplexer is not perfect and a lot of people have been having jamming problems, myself included. Eventually it just broke.
I did a redesign without the steel tubes and I have about 30 hours of print time on it with no problems so far.
Here's the link if you want to give it a try.
https://www.thingiverse.com/thing:2740929
I have a whole topic on it if you're interested in more detail.
The End G-code should retract the filament into the steel tubes, leaving it in a good state. I routinely re-print with the same four spools installed (just remove prints, and clean bed) without jams.
G1 E-4 F2100.00000
G91
G1 Z1 F7200.000
G90
G1 X245 Y1
G1 X240 E4
G1 F4000
G1 X190 E2.7
G1 F4600
G1 X110 E2.8
G1 F5200
G1 X40 E3
G1 E-15.0000 F5000
G1 E-50.0000 F5400
G1 E-15.0000 F3000
G1 E-12.0000 F2000
G1 F1600
G1 X0 Y1 E3.0000
G1 X50 Y1 E-5.0000
G1 F2000
G1 X0 Y1 E5.0000
G1 X50 Y1 E-5.0000
G1 F2400
G1 X0 Y1 E5.0000
G1 X50 Y1 E-5.0000
G1 F2400
G1 X0 Y1 E5.0000
G1 X50 Y1 E-3.0000
G4 S0
M107 ; fan off
M104 S0 ; turn off temperature
M140 S0 ; turn off heatbed
G28 X0 ; home X axis
M84 ; disable motors
Odd. I'm running the latest firmware and the latest slic3r on the Mac and it wasn't showing that g-code...the new installation on the PC shows it for Slic3r, I'm poking about but haven't found the relevant parts of PrusaControl to see if it has it or not.
I am on a Mac also. Slic3r 1.38.6 Make sure the wizard either loads the MMU stuff for you, or you use "LOAD CONFIG BUNDLE" to load the INI file.
If you use OctoPi/OctoPrint, you can put this post GCODE in the "cancel" section to make a print canceled by OctoPrint perform correctly as well.
The stop print on the front panel (from SD card) has its own behavior which includes a full unload (option).
