Adding filament midprint
christopher.d3
(@christopher-d3)
I have a long multiple material print running and one of the filament spools may run out before it’s finished. I have another spool and I would like to know how to swap it in without losing the print. Can I just use Change Ftlament or should I Pause the print first? Thanks.
Respondido : 20/10/2017 1:10 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Adding filament midprint
Use Change Filament while the filament you need changing is printing.
Peter
Respondido : 20/10/2017 2:51 pm
christopher.d3
(@christopher-d3)
Thanks.
Respondido : 20/10/2017 4:31 pm
