Soluble Interface on build plate only
Greywolf 55
(@greywolf-55)
I just upgraded my MK3S to MMU2. I want to try out soluble supports in a print. According to https://cdn.prusa3d.com/downloads/manual/prusa3d_manual_mk2mm_en.pdf?2 , paragraph 7.2.1 there should be an option "build plates only, soluble interface" in order to save expensive soluble material. On my Prusaslicer I do not have this option, only the other four mentioned in the manual. What can I do?
Posted : 15/08/2019 7:15 am
Lichtjaeger
(@lichtjaeger)
RE: Soluble Interface on build plate only
You stated you have an MK3S MMU2S but you asked this in the MK2S MMU1 forum and pointed to an old MMU1 manual.
In PrusaSlicer this is no longer a support setting but a print profile for both MMU options.
Posted : 15/08/2019 12:25 pm
Greywolf 55
(@greywolf-55)
oops sorry, thanks a lot!!
Posted : 16/08/2019 8:05 am
