Problems with PVA PrimaSelcet retraction
Elvir
(@elvir)
Hello guys
i need some help. i have problems with PVA filament. the thing just doesn´t want to retract. after printing the first layer it always stays in extruted until MMU error comes out.
anyone with simiral problem?
Thanks in advance for any help
Opublikowany : 30/06/2020 6:36 am
Lichtjaeger
(@lichtjaeger)
RE: Problems with PVA PrimaSelcet retraction
Did you dry the PVA before/during use? Moist PVA will easily get grinded by the gears what will result in a blockage.
Opublikowany : 30/06/2020 6:55 am
Elvir
(@elvir)
Yes i did, its dry.
but most interesting thing is, when i use the function filament unload it retracts normaly. But when I start to print a model it just stays blocked in extruder after the first layer.
This post was modified 6 years temu by Elvir
Opublikowany : 30/06/2020 6:57 am
Elvir
(@elvir)
I belive my problems lays in Filament Sensor. Sometimes when the filament(PVA) is inside the extruder it just shows 0, after i reset the printer.
When i tried to test the sensor with allen key or with some ends of  other filament (also tried it with PVA) it always works perfectlly. it always turn to 1.
Opublikowany : 30/06/2020 7:47 am
