Filamentum issues
SteveS
(@steves)
Filamentum issues
Been printing away for ages with no issues using PETG but switched to Filamentum PLA as i wanted the bits in Yellow (its the Melon Yellow which doesn't seem to be available now?)
Anyhow, first couple of prints fine. Third print of the same item was failure, the following two, the same. Left it overnight and tried again. Printed a silver PLA of the part, no problem. Switched to the yellow, printed two bits, no problem. Third one? failure.
They looked like the plastic hadn't set whilst the layers were being printed.  Also, seems like this filament isn't sticking to the smooth sheet well. Washed and cleaned as I normally do.
Any thoughts?
Napsal : 28/01/2021 8:54 pm
Robin
(@robin)
RE: Filamentum issues
Any pictures?
Napsal : 31/01/2021 10:50 am
