Z axis problem
merlin10
(@merlin10)
Z axis problem
Hi !!! (I have alredy share my problem here: https://www.facebook.com/groups/Prusai3users/1096110067240140 )
From two days ago, I have one problem with my printer. As you can see on the photo (and video),left Z motor is just fine but the right motor periodically as if to stop working.When I printing, or when I run calibration etc... I checked all the wires, reset to factory settings and still have the same problem.
Any solution?
Printer is MK2S with MMU1
Thank you
Video is here: (watch on 0:36)
Older video (before flashing firmware:)
Opublikowany : 31/12/2018 12:20 pm
Rosparovac
(@rosparovac)
Re: Z axis problem
First of all try to reflash you firmware and reslice your print to defaults profile.
Ok try to change cable from one Z axis position to another. If start to making problems right motor, it is rambo/gcode/ FW. If problems stays on left side there is connector/cable/motor itself.
Start from there.
University: MK2S upgraded to MK3 with MMU2.0
Home: MK3
Materials: ABS; ASA; PETG; PET; PLA; Nylon; Nylon Carbon; CPE;
SW: Freecad 0.18; Slicer PE And still generating more troubles than whole forum together.
Opublikowany : 03/01/2019 10:31 am
