Under-extrusion issues
adam.o3
(@adam-o3)
So I'm having some fairly dramatic under-extrusion issues and I have no idea what the issue is. I'm using s3d as a slicer. It seems like the infill is good, but for some reason the outer shell is a trainwreck.
After repeatedly messing with the slicer settings (increasing outer shells, increasing extrusion rate, etc...), ran the file through Netfabb, and even used meshmixer to "make solid". I inspected the mesh closely and it looks fine, yet I was still having problems, so I printed a calibration cube which came out fine.
So I changed the filament to the original Prusa filament and tried again. The situation improved (ignore the ringing, I need to replace my bearings and tighten the belts as I have done 0 maintenance on this printer in the past year), but there are still some blatant under-extrusion problems on the surface.
The infill looks good, so it looks like its just a surface issue. It was even to the point where I suspected that I had the wrong nozzle size/type for the outer shell or something weird like that, but no everything looks fine. I even uninstalled my slicer and reinstalled an updated version, same issue.
I realize I should post my settings (can't do it now but can upload later). but I was wondering if anyone had any similar problems with surface issues that might point me in the right direction to WTF.
Veröffentlicht : 11/12/2018 7:51 pm
adam.o3
(@adam-o3)
Re: Under-extrusion issues
Welp, in case anyone is wondering, I decided to risk it and print a different huge project anyways and it is printing fine, so it looks like the problem is with the model or the slicer. Hopefully this is of use to someone someday.
Veröffentlicht : 11/12/2018 11:13 pm
