Slic3r PE v1.41.0+ issue w/ Multi STL print
speedaemon
(@speedaemon)
I have a print that I've separated out into 3 STL files to try to print with my MK2S MMU1 printer...
https://www.screencast.com/t/03vAbMcbZT
The problem is, when I start the slice, the wipe tower goes away...
https://www.screencast.com/t/ut2OIAc108A
This looks to be because it somehow drops the eyes from the print, leaving it with just 1 extruder the entire print...
https://www.screencast.com/t/CyIrXxra
I imported all 3 STL files, I set a different extruder for the body and the eyes, and looks to be correct in the preview...
https://www.screencast.com/t/lqeXdRLFYbv
Any ideas why the eyes aren't being included in the print? I separated them out using Meshmixer.
-Sarkis-
Opublikowany : 12/10/2018 9:23 pm
