Prusa Slic3r PE Bug 1.41.2+win64
Scott VanKirk
(@scott-vankirk)
My Slic3r is outputting invalid GCODE. After installing the new Slic3r, I generated the gcode a couple of models in PLA. So far so good. Next, I sliced the same model using PET settings with higher temps. Now when I try to re-slice the model with PLA settings again, it is stuck using the PET temperatures. I finally had to modify the GCODE by hand to correct the temps, but this is not a solution.
Can anyone give me some ideas here?
Another clue - when I take my GCODE file to my prusa mk2s MMU1 and try to run it, it tells me that the file is incomplete and do I want to use it anyway? If I go ahead, the model prints just fine.
Veröffentlicht : 20/12/2018 10:48 pm
Martin L.
(@martinl)
Mitglied
Re: Prusa Slic3r PE Bug 1.41.2+win64
Hello Scott,
Thank you for noticing this and for taking the time to report it here. The information has been passed upstream and our Slic3r team will look into it.
❗ For others reading this bug report: under these particular circumstances, Slic3r is not updating the filament information page, but it the gcode, the correct temperature settings are saved anyway.
Martin L.
Official Prusa Research CS
Veröffentlicht : 29/12/2018 1:27 am
