PLA + PVA
I made some tests with soluble interface with PVA+ ( https://shop.prusa3d.com/en/special/169-primaselect-pva-soluble-support-500g.html?search_query=pva&results=7# ), first with the original settings in Slic3r PE, that did not succeed.
Searching around the Internet I made some settings that gave me a quite decent result:
Lowering the PLA speed in all makes the print take very long. Only 2 or 3 layer above the interface would be in need to printed slow, the rest could be printed with normal speed.
As the support (interface) simulates a print bed , the top layer of the interface should be completely closed, else the area to be printed next is not completely flat. Even with pattern spacing "0", there are holes in the interface and BTW: why to print the whole support solid???
So my question is, for the next version of Slic3r PE, could there be some improvements for printing with PVE+?
Napsal : 13/07/2018 9:31 pm
