MK2S MMU 1 filament change not working - PrusaSlicer settings?
After a quite long time, I wanted to print something with the MMU. My problem is, that the filament seems not to be retracted enough when it's time to change. So the second one can not be loaded properly. The result is no extrusion.
Is there a setting in PrusaSlicer to setup the length of filament 1 to be retracted before loading filament 2?
Napsal : 23/12/2020 8:23 am
