Message "Default settings loaded" when trying to connect via Octopi/Raspberry Pi
alf wilhelm.h
(@alf-wilhelm-h)
I did install a Raspberry Pi with octopi software. After latest update I turn on all systems, printer is ready but first time opening the web browser from octopi.local I get this message "Default settings loaded" and can`t connect. Push the Prusa knob, message dissapears and the Octopi connects immediately.
Any suggestions?
Napsal : 26/03/2018 5:52 pm
marek.w
(@marek-w)
Re: Message "Default settings loaded" when trying to connect via Octopi/Raspberry Pi
I have the same problem. "Default settings loaded" every time i turn on the printer. How can we get rid of this? Please help. I did XYZ calibration and also did the "first layer calibration". The default setting for which feature is meant? What else coud i configure, that no default settings are needed? This happens with the latest 3.1.0 firmware for the MK2.
Napsal : 03/04/2018 9:02 am
marek.w
(@marek-w)
Ok, i found this issue on github.
https://github.com/prusa3d/Prusa-Firmware/issues/461
So we need to install a custom third party firmware to get rid of this behaviour. But anyways i would like to know, which feature is meant. Because the XYZ calibration is saved and definetly no default setting.
Napsal : 03/04/2018 9:09 am
