How to rotate purge/wipe tower?
Bytor
(@bytor)
Is it possible to rotate or change the shape of the purge/wipe tower? I need to either rotate it or make it longer/skinnier than it currently is.
Using Slic3r PE 1.41.2+win64.
- 1st "printer" TIKO 3D
- 2nd PRUSA i3 MK2S with MMU v1
- 3rd PRUSA i3 MK2S
- 4th PRUSA i3 MK3 with MMU v2- 5th PRUSA i3 MK4 (upgraded from MK3) with MMU v3 (upgraded from…
Napsal : 10/02/2019 5:32 pm
Peter L
(@peter-l)
Re: How to rotate purge/wipe tower?
Yes, look under the Wipe Tower Settings. There's a setting for the tower width, and a setting for the tower angle.
Napsal : 10/02/2019 6:07 pm
Bytor
(@bytor)
Where is the "Wipe Tower Settings"? I went thru all the settings and I don't see anything labeled as Wipe Tower... time for new glasses???
- 3rd PRUSA i3 MK2S
Napsal : 10/02/2019 10:26 pm
On The Spot
(@on-the-spot)
Easy to miss - Under Print Settings Tab, Select "Multiple Extruders", you'll see it there:
I've had a couple of complex prints that the only way I could fit the wipe tower in was by changing the "Rotation Angle" to 90 degrees.
Napsal : 11/02/2019 6:28 am
Bytor
(@bytor)
Michael,
Thank you very much... I guess I do need new glasses (or brain) because I could have sworn I had been up and down all the settings and I didn't see that. I saw certain wipe functions under Printer Settings, but no where else.
- 3rd PRUSA i3 MK2S
Napsal : 11/02/2019 1:33 pm
CybrSage
(@cybrsage)
RE: How to rotate purge/wipe tower?
Posted by: Bytor
Michael,
Don't beat yourself up.  They changed so much (for the better) that we now have to relearn the program.  I also have missed items that appeared obvious once they were pointed out to me.  🙂
Napsal : 13/05/2019 11:22 pm
