Hotend thermistor replacement for MK2S
NotSure
(@notsure)
Hello,
I'm looking for thermistor replacement for my MK2S printer, does anyone know where can I buy one?
Basically, I had almost the same problem as described here.
I could not find it in the Prusa Online Shop and haven't got any response to my email/messages.
I can try the one mentioned in the post, but I was wondering if it's the correct part for my printer.
Thanks.
Opublikowany : 22/04/2018 12:33 am
Re: Hotend thermistor replacement for MK2S
Hi Notsure, were you logger in to the website when looking for parts, if not, they are hidden from view.
Opublikowany : 22/04/2018 2:57 am
NotSure
(@notsure)
That did the trick, thank you! I can see more parts now, including the thermistor (E3D V6.1) though it's marked as "Out of stock".
I've also got a response from Prusa support, hope they will be able to help me.
Will post any updates here.
Opublikowany : 23/04/2018 5:39 am
NotSure
(@notsure)
A quick update: got the thermistor, followed the guide to replace it, then performed XYZ calibration - everything works fine now!
Opublikowany : 11/05/2018 10:46 pm
