Hotend thermistor replacement for MK2S
Hello,
I'm looking for thermistor replacement for my MK2S printer, does anyone know where can I buy one?
Basically, I had almost the same problem as described here.
I could not find it in the Prusa Online Shop and haven't got any response to my email/messages.
I can try the one mentioned in the post, but I was wondering if it's the correct part for my printer.
Thanks.
Re: Hotend thermistor replacement for MK2S
Hi Notsure, were you logger in to the website when looking for parts, if not, they are hidden from view.
That did the trick, thank you! I can see more parts now, including the thermistor (E3D V6.1) though it's marked as "Out of stock".
I've also got a response from Prusa support, hope they will be able to help me.
Will post any updates here.
A quick update: got the thermistor, followed the guide to replace it, then performed XYZ calibration - everything works fine now!
