File Incomplete: Slicer 1.41.1 RC
frank.m
(@frank-m)
Hey Mates,
Just upgraded pSlic3r to 1.41.1 RC and my printer screen reads, "File incomplete, continue anyway?" for each *.gcode file i've created since. The export G-code process appears to work and complete correctly from pSlicer. tried to generate a few different files using different models in case it was just due to the models used.
Anyone else seeing this? anyone tried to proceed anyways? did it work? my next print is something rather large, so I hesitate to proceed if tehre is a chance of wrecking 300m of filament lol
Postato : 11/10/2018 1:48 am
toaf
 toaf
(@toaf)
Re: File Incomplete: Slicer 1.41.1 RC
are you on the right printer settings in slicer?
Postato : 11/10/2018 2:12 am
frank.m
(@frank-m)
yea, pretty sure. Set to MK2 MMU multi-material, which is what I need for the files created.
Postato : 11/10/2018 2:39 am
Check the gcode file in an editor, particularly the end. You should see the gcode from your Slic3rPE settings.
Postato : 11/10/2018 3:37 am
Hannes
(@hannes-3)
Same problem here, FW 3.1.0 always reports "incomplete" despite the .gcode files looking and working just fine.
Postato : 21/12/2018 10:05 pm
raphi
(@raphi)
I have the same problem since I updated the firmware to 3.1. The same gcode file I printed with 3.0.12 does prompt the file incomplete error message now with 3.1 and it does this with every gcode I have, the latest created with build: Slic3rPE-1.41.2+win64-full-201811221420
It's not the filename, one has the name cprot3.gcode and prompts the error too. This is the end gcode I use:
{if not has_wipe_tower}
; Pull the filament into the cooling tubes.
G1 E-4 F2100.00000
G91
G1 Z1 F7200.000
G90
G1 X245 Y1
G1 X240 E4
G1 F4000
G1 X190 E2.7
G1 F4600
G1 X110 E2.8
G1 F5200
G1 X40 E3
G1 E-15.0000 F5000
G1 E-50.0000 F5400
G1 E-15.0000 F3000
G1 E-12.0000 F2000
G1 F1600
G1 X0 Y1 E3.0000
G1 X50 Y1 E-5.0000
G1 F2000
G1 X0 Y1 E5.0000
G1 X50 Y1 E-5.0000
G1 F2400
G1 X0 Y1 E5.0000
G1 X50 Y1 E-5.0000
G1 F2400
G1 X0 Y1 E5.0000
G1 X50 Y1 E-3.0000
G4 S0
{endif}
M107 ; turn off fan
{if layer_z < max_print_height}G1 Z{z_offset+min(layer_z+30, max_print_height)}{endif} ; Move print head up
M104 S0 ; turn off temperature
M140 S0 ; turn off heatbed
G28 X0 ; home X axis
M84 ; disable motors
Any idea what's causing this? The printer does print the gcode anyways and the end gcode seems to work too, so it's not super urgent. But it'd be still nice to get rid of this message or at least understand what's causing it.
Postato : 10/01/2019 8:54 pm
fabio.s
(@fabio-s)
RE: File Incomplete: Slicer 1.41.1 RC
Did anyone find a solution to this problem?
I'm having the same issue.
I have tried with the new PrusaSlicer 2.0.0 but the problem still occurs. 😢
Postato : 25/05/2019 8:15 am
