Color change retract amount
EddyMI3D
(@eddymi3d)
Hello!
Where in Slic3r can I set the amount of filament that is retracted/primed during filament change?
Thanks in advance,
Eddy
Respondido : 24/01/2018 1:36 pm
devon.b3
(@devon-b3)
Re: Color change retract amount
Bump!
I'm also curious about this. I'm printing with HIPS for support material and if I switch between filaments (MH Ryno) too often the HIPS often doesn't retract enough to clear the metal tube in the Y. This jams the next material going in and effectively makes the print fail.
Respondido : 12/02/2018 3:24 am
EddyMI3D
(@eddymi3d)
Hello devon!
That is exactly my intension.
Would be optimal to have a certain additional retract on just one extruder
Respondido : 12/02/2018 6:09 pm
VegasTim
(@vegastim)
It is on the "printer" tab under extruder
Respondido : 13/02/2018 7:27 pm
devon.b3
(@devon-b3)
@tim.t8 yeah I see the retraction option in Slic3r but it seems to be overwritten by the printer upon running the gcode. I've read that the value shouldn't be set much more than 4mm but as I mentioned before i'm getting this weird mushrooming that jams the multiplexer below the cooling tube but above the PTFE at the heatbreak. I think it may be related to the HIPS not being retracted all the way into the cooling tube.
Respondido : 13/02/2018 8:48 pm
EddyMI3D
(@eddymi3d)
And these 4mm are way too few to retract the filament from the hotend into the joiner. This must be about 55 mm or so.
Respondido : 15/02/2018 10:07 pm
supermerill
(@supermerill)
I think it's hardcoded right now. A work is in progress to make the thing configurable.
Respondido : 27/02/2018 4:50 pm
jperch
(@jperch)
I have had two successful multi color prints and several single extruder prints. My printer then sat idle for a month or so. Now I seem to be having this exact same problem on multiple extruders even when just running a single extruder.
At first, I thought it might be a problem with my filament as it is not on the "tested" list. But I tried a single extruder print with Prusa filament (what came with my printer) and it jammed again. The filament seems to be jamming right at the bottom end of the steel tubing. It jams so hard that the extruder can't move the filament forward or backward.
If adjusting a retraction setting would correct this, I think we really need to get that feature. It seems like just 2 or 3mm more should do it.
Joe
Respondido : 28/02/2018 5:30 pm
jperch
(@jperch)
I just had another thought about this. What if it isn't a distance setting but a retraction speed setting that needs to change? What if the material cools faster than the retraction can get it into the cooling tube and the material hardens before it gets to the bottom end of the tube? That would jam it up good.
Could it be that the extruder doesn't need to retract more distance but the same distance just faster?
Joe
Respondido : 28/02/2018 5:34 pm
EddyMI3D
(@eddymi3d)
Hello Joe!
I don't think that could be the cure because of the non existence stiffness of flexible filament, it curls up in the bowden tube,
so even fast retraction would not pull back all of it away from the joining point, so that other filaments get stuck
Ewald
Respondido : 02/03/2018 9:08 pm
