Bed calibration point not found after PEI replacement
felipe.s
(@felipe-s)
HI, I had to replace the PEI sheet on my MK2S MM after a couple tears showed up from overly-sticky TPU prints, unknowingly I bought 1mm PEI, which I like very much after install, but the printer will not complete the XYZ calibration. I have lowered the PINDA sensor so it is about .5mm above the nozzle. I also had to replace the nozzle thermistor after constantly getting thermal runaway errors.
I am able to run mesh leveling successfully, but I always get an error on point 2 (mid-right) of the basic calibration. I have already ordered a new generic PINDA sensor and a new .5mm PEI sheet on amazon, but I would like to be able to fix this issue without tearing the printer apart yet again to replace the bed PEI sheet.
Any ideas on how to fix this issue?
Thanks
Opublikowany : 16/07/2018 6:51 pm
