Bad stepper or driver?
Deku
 Deku
(@deku)
I have recently started hearing this ungodly noise coming from my x axis stepper. Is the stepper going bad or is it my board that needs to be replaced?
Veröffentlicht : 24/03/2021 5:00 pm
Deku
 Deku
(@deku)
RE: Bad stepper or driver?
https://youtube.com/shorts/lJR4xE8u0_w
Video from original post wasnt working. Uploaded the video to youtube
Veröffentlicht : 24/03/2021 5:13 pm
Clarmrrsn
(@clarmrrsn)
Have you lurbricated the bearings and rods recently?
Prusa Knowledge Base | Maintenance tips (prusa3d.com)
Check the belt tension as well
Prusa Knowledge Base | Adjusting belt tension MK3/S (prusa3d.com)
Finally check the idler pulley on the RHS, the bearing in them can fail and start grinding
You can also switch off and move the carriage very slowly back and forth, (dont move too quick) see if you can track the noise down to one particular area.
Diese r Beitrag wurde geändert Vor 5 years von Clarmrrsn
Tank you very much!
Veröffentlicht : 24/03/2021 5:17 pm
Deku
 Deku
(@deku)
I have checked the belt tension and lubricated the bearings but i am still getting the noise. The noise is not always present either. It only happens occasionally but it is there for every print. I did not hear anything resembeling that noise when i manually moved the carriage.
Diese r Beitrag wurde geändert Vor 5 years von Deku
Veröffentlicht : 27/03/2021 9:10 pm
