Parts common between MK2S/MMU and MK2S aren't identical
I wanted to print a replacement set of x-axis parts (specifically the idler and the motor mount) and noticed that they're not the same between the two archives. One obvious difference is that the MKS2S/MMU archive parts lack the support ribs.
Is that intentional? What should I be printing? I'll admit I only noticed when checking up on the print and realizing that the part on the bed didn't quite match the part printing it.
For anyone curious, I cracked the idler part a little bit. It works, but now that I'm printing pretty well, I wanted to replace it before I ran out of orange ABS.
Re: Parts common between MK2S/MMU and MK2S aren't identical
I think the Mk2S came out after the MMU version. possible why the parts for the Mk2S are more robust.
