The PTFE tubes are going out one by one. How do I fix this?
theologos.m
(@theologos-m)
After some years of using our i3 Mk2S - multi-material the PTFE tubes are starting to get out when the nozzle clogs.See the attached image.
The problem is that now if I put the tubes back, they will not stay there and they will get out immediately. I tried to cut the endings but it isn't working.
How can I make the tubes stick in the extruders again?
Attachment removed
Opublikowany : 30/05/2019 7:55 am
PJR
 PJR
(@pjr)
Antient Member Moderator
RE: The PTFE tubes are going out one by one. How do I fix this?
You need to replace the Festos.
I had 8 or 9 of them give up after a lot of use.
Peter
Opublikowany : 30/05/2019 12:33 pm
theologos.m
(@theologos-m)
Thanks Peter!
Festos? Do you mean that small metallic pieces with blue collars which are screwed on stepper motors?
From where can we purchase them?
TIA for your support.
Opublikowany : 30/05/2019 1:21 pm
PJR
 PJR
(@pjr)
https://shop.prusa3d.com/en/mmu2mmu2s/165-mmu-festo.html
Depends where in the world you are.  eBay may be cheaper if you want to buy a pack of 10, or you should have a local Festo outlet (Google will help with this) where you can buy in greater quantity, but a lot cheaper.
Peter
Opublikowany : 30/05/2019 6:04 pm
